Br500 on a 7-bolt
Harris91
May 4, 2004
Powell, Ohio
Winter is coming, and I plan to upgrade to the Br500. I will have all supporting mods, but no internals. 680's or 720's (haven't decided yet) safc-2, fmic, 255,etc. If I have all supporting mods, do you think its safe to run this size of turbo? Shooting for 18psi daily, and more at the track. Thanks in advance guys. ;)
go with the 750cc injectors to make sure you dont run out of fuel and get a fuel pressure regulator to insure that your S-AFC can control the amount of fuel you are flowing. 18psi would be fine. make sure you have an intercooler that will flow well and you should be ok.
best of luck on the build.
Thanks for the response. I will probably go with 750's because I will probably set the boost at
low to mid 20's when I go to the track, and throw in some 104 octane. :)
