6 bolt arp bolts on a 7 bolt...
jdd1231
108
Jan 6, 2009
Cherry Valley, Illinois
ok,may be a dumb question but:
Ive got arp head,rod & main bolts bought for a 6 bolt.
Will these work on a 7 bolt?
The rod bolts no unless your using 6 bolt rods, head bolts wont unless your drill and tap your block, the mains will also work.
so the head bolts are bigger maybe?
I didn't think the rods would because the 6 bolts have bigger rods? :idontknow:
Yes the 6 bolt head studs are 12mm and the 7 bolts are 11mm if I remenber correctly.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
