joebor1776
- 49
- 0
- May 17, 2007
Cincinnati,
Ohio
Hi,
I just removed my air filter assembly (K&N, no box) to do my first boost leak test. The previous owner installed the K&N filter and apparently installed the hard pipe that the BOV is attached to upside down. I can see two small bolt holes on the bottom of the BOV bracket (which is facing up). When I do the boost leak test, tons of air flows out one of these holes. My question is, should I try to block this hole to seal that leak, and if so, what should I use? This is a huge leak, and my car seems to be boosting pretty well--I didn't suspect such a big leak. I'm just wondering if it is maybe supposed to be leaking air from there. My BOV is not vented, btw.
Thanks!
Thanks!
