PDX-GST
- 32
- 0
- Mar 5, 2012
Aloha,
Oregon
I have been working on fixing multiple boost leaks over the last few weeks and have fixed all but one small leak at the weld on the bov flange. It hold pressure pretty well now so I thought my stuttering issues would be gone.
They remain, and even sometimes with the throttle wide open it will start to stutter then the blow off valve will quickly open for a second at about 12psi then keep stuttering.
If this isn't a boost leak issue anymore what could be causing the blow off valve release without letting off the throttle.
Could it be an issue with vacuum? What exactly initiates the release of the blow off valve?
Yes I guess it was. Sorry I have never experienced a misfire and it sounded like my bov opening. Unless the misfire caused vacuum to open the bov. But regardless thanks.
