BOV nipple?
dragonov_elite
270
6
Jul 14, 2005
La Crosse, Wisconsin
Just came from looking at the form to install the greddy type s bov. I have a hose disconnected from my greddy type s bov. The nipple for the hose is found on the opposite side of the dump tube that expels exces boost.
I am wondering how will my car run with this hose detached? Where would i attach this hose to? Is this hose nesesary to proper operating procedures? Where would i be able to buy this hose?
I bought the car with the bov installd so i do not have the vacum hose for that nipple. Help would be appreceated.
Thanks
sorry if my grammer is not up to par.
is it a little port sticking out from the BOV?, sorta pointing toward the intake manifold?, and is there an open port on the front, left side of your intake manifold?
there needs to be a hose running from the top of the bov(in your case) to the intake manifold, you an use just about any silicon hose, i think its the 3mm hose, could be 2 though
while under boost, pressure is pushing up, while the exact same amount of pressure is pushing down which is coming from this hose, this keeps the bov closed, then as soon as you let off the throttle, boost in the manifold is cut off by the throttle body butterfly valve, vaccum is now in the intake manifold which pulls on the BOV and allows the presurized air left in the IC piping to push its way up and be released through the BOV and into the intake to help the turbo stay spooling between shifts. NOw that we cleared up what the BOV is used for, you need that hose,LOL
OP: Please clarify which hose/nipple you are referring to. If you're referring to the bottom nipple on the underside of the BOV body, just leave it alone. Some people prefer to cap it, some don't. On some applications, you're supposed to hook that hose up to a pressure source to help the action of the valve, but in the case of the DSM, it's best left unhooked up.
As long as the top nipple is connected to the intake manifold, you'll be fine.
Edit: And don't forget to recirculate if you're not already doing so.
I have read up on the type s. I found that if you hook that other nipple up to a pressure source that will give the type s its TING sound over the typical bov pssshh sound.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
