Lower BOV nipple.. Uses????
Drift_SM
772
5
Jul 28, 2005
Titusville, Florida
Every one knows the the type s BOV has the 2 nipples on the back side of the BOV, the top one is for the intake manifold hose. But what is the smaller (skinnier) nipple for right below it?
I searched and found only one good use, that you can connect it to an intercoller pipe..?
Other then that just plug it.
What happens if you dont plug it?
Whats that nipple for?
IIRC its to help the valve move faster. Everyone that I've talked to doesnt plug it in including me
It helps prevent compressor surge by using a pressure source to help open the BOV faster. You could tap it into the IC piping, but I have mine tapped into the compressor housing and it works like a charm.
EDIT: It makes the BOV alot louder as well. Another plus:thumb:
Just leave that smaller nipple below alone. No vaccuum line to anywhere and do not plug it.
If i remember correctly its to help the BOV actuate quicker. and your not suppose to plug it, your suppose to leave it open. bad things can happen if you plug it.
Hooking the bottom nipple to an intercooler pipe puts pressure on the bottom of the diaphram. and so does the top one (intake mani source) so there is equal pressure on both sides, and the spring keeps it closed. so now what happens when the intake manifold sees vac? low pressure on top side of the BOV diaphram and high pressure on the low side. causing you guessed it a super quick release.
Hope that explains things somewhat:laser:
So it sounds like if i hook this up its going to benifit me a little bit.
can I connect it to the compressor housing like said above? thats basicly an inter cooler pipe correct? its a boost source.
let me know.
Thanks every one.
-alex
let me know.
Thanks every one.
-alex
you can hook it up to and boost source that is before the throttle body but after the compressor housing (obviously) so the j pipe, the intercooler just before the tb, anywhere you choose. doesnt matter hot or cold side.
I have never had a problem with my setup. Even when I spliced into the compressor housing line that connects to the boost controller.
Why does it have to be after the copmressor housing?
I know this is an old thread but i had a question like this and just so I got it straight. My top one goes to intake manifold and the bottom one leave unplugged and not ran to anything? Mine was plugged when I got the car...
I heard that this is where your supposed to hook of a boost controller, It doesnt work.. I guess leave it un plugged but what are we supposed to hook up a MBC on the PR FMIC kit?
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
