1g bov nipple?
evo916
Oct 9, 2006
airdrie,
where does the nipple on the bottom of the 1g bov go to(pressure source nipple??), before i had it routed to the j pipe but i rerouted my mbc to the jpipe/wastegate instead of how it was before (bov line/wastegate) i have a maft and gm maf my bov is vented also i searched but couldnt find a place to route it
thanks for the reply, nvm i found out that my bov is modded and that is why there are 2 nipples coming out of it so my issue is solved
do you have info on how your bov is modded? I know about the typical crushing and I've heard of modifying the diaphram to hold more boost/deliver quick shifts
oh yeah, you really want the bov sensing changes as close to the TB butterfly as possible. Compressor surge/charge pipes falling off is a bad thing
yeah the bov is modded using the 1g bov mod in http://www.vfaq.com/index-main.html i found out that it doesnt have to be connected to the j pipe, but on a side note can i tap another nipple into the j pipe to connect this extra bov port up again or will it mess with my mbc which i have hooked up to the original nipple in the j pipe??
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
