Both of my pwr windows stopped working???
flyinghighlm
345
4
Sep 27, 2005
charleston, South Carolina
Well I tore the car apart to rebuild the motor and I have not tried using the windows for months now. I also had the doors apart to put in new speakers, but I made sure everything was reconnected. Why would both windows stop working, no matter what switchs I use? Is there a relay or fuse, something I can check????
Thanks, I tried that but no joy.....could I have snapped a fuse or realy messing with my stereo install, like a power surge or something went through the system, when i reconnected the battery and all that....next bet is I can get a hold of a volt tester but where should I be looking to test to make sure I have power???
have you checked the window fuse yet ? and start with the hot wire to the motor you can also do this with a test light ! follow up with us!
fifthgearvtec said:
have u checked the window fuse yet ? and start with the hot wire to the motor u can also do this with a test light ! follow up with us!
Will do in the next few nights, work right now is taking up to much time. Thanks again, and I will update ASAP
FYI I figured it out, now I knew my battery was low on power but the radio and evything else worked so I figured that was not it. Well it was, low and behold i found out that those motors require 10-11 volts in order for them to work. My battery was down to 9 volts so thats why they did not work properly.
