Resolved 1G Power windows not working
93_tsi_fwd
2,624
17
Dec 20, 2006
San Jose, California
i recently bought a 91 eagle talon tsi awd. the windows does not roll up or down. both of the motor is working. the controls are working fine. i looked under the dash for a fuse for the windows but nothing, i checked all the fuse, even inside the engine bay.
If the window lock isn't on, then maybe someone took the door panels off and forgot to plug back in the harnesses. Its highly unlikely for both the windows not being able to roll down at the same time.... Look at vfaq.com for more info about known window problems.
when i got the car both of the windows were down. i removed both of the door panel the close the windows. i directed it to a battery to close it. i sure i put back the plug on both of them.
is there a fuse for the windows? i looked at the fuses. ill check vfaq.com if theres a fuse for the window.
Yes, do some investigation behind your door panel to try and find anything out of the ordinary. Double check everything plus the connections and WINDOW LOCK BUTTON. I had once flipped out because of that button and not realizing it was down. Ish was hilarious. Good luck and post back.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
