Boost wont turn up
TeeM403
Aug 2, 2012
Calgary, AB, Canada
Okay so i upgraded manual boost controllers and im pretty sure i hooked the vacuum lines up correctly and for some reason the boost wont turn up it only boosts the stock 9psi or w/e. not sure what it is if i did hook the lines up backwards would this be the result ?
Look up a diagram to verify that you have it hooked up correctly. Do you have a mechanical boost gauge? Make sure that it is hooked up as well.
If you have a aftermarket boost gauge and the boost controller hooked up correctly, then look for a pretty large boost leak... LOL
Get a boost gauge. Also if you think you hooked up the vacum lines wrong then you did check them again. If that doesn't work then time for a boost leak test.
I have an aftermarket boost gauge LOL and the thing is i had a shitty homemade boost controller on there before and then switched to stock mbc for a bit and havent drove it ### winter now i put a new one on and it wont turn up i dont think i have a major boost leak but ill check if i hooked the lines up backwrds
if your current boost is stuck at 9psi and doesnt drop off there is no boost leak im sure, the lines are just backwards.move em around and you should be good to go. a full turn on most mbc's is about 2-3 pounds.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
