Boost problem
dsmulla
200
Jun 27, 2007
Scarborough,
Ok guys, I have been trying to fix this problem for the past week but I haven't gotten anywhere.
My car would only boost to about 10 psi and it would take a lot of effort to get there. I checked the wastegate arm and reconnected it to the turbo with some tension so it keeps the wastegate closed. I thought that would fix the problem but it didn't however, I do get boost around 3000rpm which is what my turbo is rated at and responds faster now. It still goes to about 10 psi though. Now I have tried doing a boost leak test but my boost gauge only reaches up -10 vaccum and it doesn't go higher.
What do you guys think could be causing the boost leak test to fail like that? Is it the wastegate flapper still open slightly?
P.S When I get on it, I can hear the leaks. I also tightned up all the couplers and I can still hear the leaks.
Thanks in advance,
Osman
Oh also, I forgot to mention, my CEL light came on a week ago. It give P01108 IAT sensor malfunction, I cleared it and it never came back on again. Well I haven't really driven the car so.....
Now as I understand, the IAT sensor is within the MAF itself right?
That is correct but it seems like your IAT sensor is functioning properly.
I am going try to take some logs and go from there. I will also take a look at the TPS and regarding so you think that the Throttle cable is too tight? I will also try to swap my MAF with someone elses locally and see what happens. I will get back.
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
