Boost problem help please
GstRacer
409
3
May 6, 2003
BooneDocks, Connecticut
ok i have upper and lower IC pipeing and a greddy type s BOV well when i put the lower piping on and went to drive the car it seems to be leaking from the BOV. i will go to get on it and the car will start studdering and you can here the BOV fluttering but before the lower IC pipes everything was fine what could the promblem be?? Boost leak somewhere eles other then the valve or the BOV i can't figure it out
I can't seem to find it on here right now b/c the search isn't working for me... anyways, there is a writeup by someone on how to properly adjust the greddy BOV... also, did you use a gasket when installing the bov? that could be your problem.
yes i used a gasket but i did n0ot connect the botom hose nipple is there soposed to be a hose on that too if so where doses that hose go too what kind of vac sourse.the top nipple is hooked up to the intake manifold
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
