Boost limit on a 50 trim turbo
Status
Not open for further replies.
Do you have any mods you could tell us about, that would possibly help us answer you. But I'm assuming that if you have a 50 trim you should have the supporting mods, you can run high boost 25-30 psi easy. *Edit. I didn't notice you said "boost limit". I guess that depends again on what size injector you have.
Yes i have the mods and we be running dsmlink. What size of injectors should i go with if i want to push 25-30psi?
Some 950cc injectors with something more powerful than a walbro 255. Maybe a Aeromotive fuel pump or a Tsnumi fuel pump. Those are good for 800HP.
Status
