95gstnj
- 60
- 1
- Feb 11, 2004
howell,
New Jersey
hey, the car is a 98 with a 6bolt. stock injectors, no fuel management. did a compression test earlier on the car when fully warmed up, wot, 150 across the board. regapped my bpr7es's .028, which the car ran fine on before the test, put all back together and started up fine.
a few mins later i decide to do a boost leak test. put the tester on the licp right after the turbo.Tightened a coupler after finding a small leak, held 18 psi fairly decently with a small leak around the magnus intake somewhere. i also wiggled the throttle shaft to check the shaft seals. one leaked a little when i moved it. didnt bother to fix it now b/c of time, and it drove fine with the leak before the test. i put the licp back on the turbo, go to start it up, and it idles really erratically, low enough that my dash lights flicker, backfires alot at idle and whenever i try to rev it. sounds like its running on 2-3 cyl. its not making alot of power right now, so i swapped in brand new bpr6es's gapped to .028. no change.
wires 2&3 are swapped (thats the way i got the car and it ran fine)
tried all diff combos of swapping wires 1,4 & 2,3 etc ran the same reguardless of wires.
a few days prior, i added a bottle of fuel system cleaner
I HAVE NO LOGGER
I already checked for any loose wires, etc i may have disconnected accidentally
throwing a cel, but was doing that before all of this.
I'm stumped.
please, any advice is better than none.
thanks
I HAVE NO LOGGER
I'm stumped.
thanks
