boost leak test
peter535
162
Aug 5, 2007
montreal,
when doing a boost leak test how long do u have to pressurise the turbo im using a 150psi compresor and im not getting anything on my boost gauge
It takes my car only about 10 seconds or less to start showing pressure in the system. If you can't get anything to show then you have a really big boost leak. If you have a manual boost controller did you take the line off of it and cap it as the boost controller itself will leak?
i dont know my friend lent me the compressor i just grabbed the hose and start pressurising LOL
yes i have a manual boost controller i didnt touch that what line do i have to take off?
Take off the line that goes from the pressurized side of the turbo (nipple on the housing/ J-pipe/ wherever the boost source is coming from) and cap this line off well. You don't have to disturb the line that runs to the wastegate acctuator.
if its not a big hole you can hear,but if lets say if you take the hose from ic and let the air in you wouldnt be able to hear well ,because the air would be coming our really fast
the hoses that where on the air intake,since i have to take it off to do the test do they have to be blocked off or something?
I would still try to get a pressure regulator!!! You don’t want to have to rebuild your head because you blew your valve seals. Or injector seals, intake gasket, etc...
As for your boost leak problem... Pull the tester off the turbo and make sure the valve your using isn’t broken, or something.
pressure regulator? whats that for
You put it between the compressor and the air chuck. It limits the amount of pressure to what you set it at. You want it to prevent 150psi of air wrecking something in your engine.:thumb: Not saying that you couldn’t get lucky and just blow off an intake pipe, but its for safety.
so you can regulate the air compressor air pressure so you dont hurt your engine! You want to set it around the amount of boost you plan on running.
LOL, beat me to it! +1
ok thanks ill look into it and as for the boost leak test does anyone have any other suggestions as to why im not getting anything on my boost gauge?
Do you have a mechanical or electronic boost gauge? If you have an electronic one, you will need to have the key in the "on" position for it to work. You most likely have a huge boost leak though.
i tried both with the key in on and off i get nothing, where can i have that big of a boost leak? i seriously dont know wher to check
Check all intercooler piping, throttle body, intake manifold, all vacuum hoses, intercooler. I'm sure there are more I have missed too. It helps to spray soapy water everywhere to identify leaks easier. If there is a leak, the soapy water will make bubbles that are easy to see.
As for your boost leak problem... Pull the tester off the turbo and make sure the valve your using isn't broken, or something.
Well??? Just put air to the tester outside of the car. If no air goes through it... ;)
LOL. Sorry dude. I forgot your the one who actually has to go outside and do this... :D Does that mean I’m impatient???
Just an idea... Pull the oil cap off and the coolant pressure cap off, hook up the tester and listen through there. It's a long shot... But maybe. Also, when you have the chuck on the valve, does the upper intake pipe get hard (the one going to the throttle body)?
Also, does the car run?
Just an idea... Pull the oil cap off and the coolant pressure cap off, hook up the tester and listen through there. It’s a long shot... But maybe. Also, when you have the chuck on the valve, does the upper intake pipe get hard (the one going to the throttle body)?
yes the car runs i just storred it for the winter so its sitting in my garage my uicp ive changed them to hard pipes
ill try the oil cap thing tomorow cz the car is in my grandmas garage witch is downstairs from my house and she locked the doors LOL she sleeps early
ok i took off the oil cap and when i do the test i can hear the air from the cap but i still dont see anything of my boost gauge
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
  • Wanted 4G63 800cc injectors
    Im looking for a set of injectors that are at least 800cc. Thanks!
    • DSM_Thorpe
  • For sale 2g 2g rear brace arms
    2g rear subframe brace arms. Missing one of the bushing spacers. No rust. Had someone looking...
