Boost leak. Possible problem
phillabaum03
849
3
Nov 28, 2005
sharpsville, Pennsylvania
Ive been having problems since i got my 6 bolt in. When i boost it studders really bad. Almost like its hitting fuel cut. I did a boost leak and found a leak between the throttle body and the intake manifold. Would that cause the studdering. I can slowly accelerate and keep the boost guage at 0 and run all the way up to 7000rpm with out no problem but if it starts to build boost it studders. thanks:toobad:
Since you did the 6 bolt sway Im assuming you know alot. How bad was the leak?
Anyleak will hurt you, period. I would get that gasket replaced as soon as possible. Then if that doesnt solve the problem we can think of more options, but yes a boost leak can cause you problem.
Also, I suggest the good old- Do you have NGK Bpr7es's gapped to .028 in you motor?
Im not sure what exactly the plugs are. I know they are NGK V-Power and they are gapped at .028.
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
