Possible boost leak
dabbdaddy
49
4
Mar 9, 2016
miami, Florida
alright so I'm still working on these boost leaks and hanging wires I got in my bay and I'm wondering about this waste gate hose (pictured below) along with the other hose that's in my hand . Is that supposed to be one hose ? Or do they both go elsewhere ?
I will try to edit better pictures in a few minutes . Thanks guys
thank you , i will try to learn as much as i can off those diagrams but i am having a little trouble with them. but what i did learn is that those cut hoses use to belong to a boost controller . my question now is if i plug those up or do they need to go elsewhere :/
If they went to a boost controller, and the boost controller was removed, then you need to replace them with a single line that joins the ends each hose is connected to.
One hose should be connected to a boost source somewhere, probably in the lower intercooler piping or on the compressor housing. The other should be connected to the wastegate.
