Boost leak or lag?
Spoolio
730
10
Sep 3, 2003
Port Charlotte, Florida
Hey i was driving home today and i was in 4th gear so i wanted to get moving a bit faster so i started pulling hard at full boost my car motor felt like it was breakin up , like my plugs were bad kinda like when it feels like when u redline and it revs up and down really fast, my car has been runnin pretty rich also , could this be the problem?, i was at a meet today and a few guys said i blew out some black smoke when i took off, so that means i was running real rich, could this be my problem?
Upgrade the wires.....As well as the coil pack you could do it for under $100 if you look well enough.
He's probably saying that you should replace your coil pack. An upgrade from the coil pack is a coil on plug setup which is something that you do not need.
Do what CandianTSi suggested you try doing and hopefully that will clear up your problem.
well i brought my car to the shop cause it was blowin oil out everywhere, and i need a new crankseal, 450$ :notgood:
