boost leak from brake booster?
spitefire1
208
Feb 7, 2008
monticello, New York
i just put a jmf smim on my car and i notice know after 5 psi of boost, their is a boost leak and it sounds like it is coming from the brake booster. know ive talke dto many poeple and they said you have to have a check valve into the line from the booster to the smim. is there one f the stock line,or stock manifold? can i buy a check valve or something to put into this line . some one please help thanks
It's built inthe actual hose that goes to the brake booster. You can test it by spraying air in one side of it and them the other and see which way it will let air through to make sure you didn't put it on backwards.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
