Octane booster for cheap! More boost!
While your running to the MAC i have some oil booster that helps oil pressure which equals more HP. PM for the address to send the cash to.
Octane boosters work. So do lead additives. I think it is wiser to follow the tuning guide and run 91+ pump, but what do I know?
Why not just tune the car correctly. Then you wont have to worry and mixing and running out of that at some point. All that is is a bandaid for a bad tune. Just get one tune for pump and one tune for race gas. When you get ti the track run the race gas and its tune and you will be fine.
I would rather do water or alcohol injection. A lot less hassle and still gives you the ability to run a good amount of boost on pump gas safely.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
