Vacuum distribution block off of brake booster line?
gprix1
275
16
Aug 11, 2009
Kingman, Arizona
I'm installing a vacuum distribution block and where it's mounted on the firewall it's right next to the brake booster line. It would be very clean and easy to put a T in the brake boost line to feed the distribution block.
Besides brakes having less effectiveness should a line pop off, would it be ok to use? Is it an accurate enough place to measure vac\boost (i.e. MAP sensor, etc)?
It will work, but I'd personally stick with a dedicated line for the brake booster and just tap another port for less critical vacuum sources. I'd hate to get caught off guard when a boost gauge line fails and my brakes stop working as expected. :)
If you are dead set on doing it, make sure to tee into the IM side of the booster line's check valve.
Excellent. Thanks for the responses.
calan: I will keep that in mind and be sure to use clamps on any lines to and from the distribution block for extra insurance.
Can you run a bov and MAP sensor off the vacuum block? Some people are saying not to "T" into bov line.
i run a identical setup and have had no issues using the brake booster line
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
