Need help finding boost/ vacuum distribution block
christiane
86
Jan 20, 2004
South Point, Ohio
I have reached a point where my vacuum lines are getting to be a pit of a PITA to deal with. I found a link previously for a boost distribution block. Does anyone know of a company that is currently making these?
Thanks for the space,
What exactly is it that you're talking about? I've never heard of what it is, so describe it.
The one I saw on ebay was like the one taboo made back in the day. You have a single boost/ vacuum inlet. and then you have 4 or 6 boost/ vacuum outlets. It eliminates the need to have all of those "T's" on your boost lines. With having the GM MAP, Methanol Injection, external WG, BOV, and the DSBC the routing of my lines looks pretty bad and this would allow me to put the distribution point on the front upper strut tower bar.
I think it is just a sealed chamber with tapped holes in it for different connections to different components that are "pressure sensitive." I think you can just get something like this off of McMaster-Carr, that is what my friend did when he was turbocharging his integra. I am not exactly sure what size you would need though, becasue that would effect all the components a lot.
Bill
You dont need any of your vacuum lines except for the P on the throttle body. Toss out all the other ones and cap off the throttlebody nipples except for the P. (less boost leak possibilities too!)
Emissions = :notgood:
