boost leak behind the TB, no clue?
shadowdrag
191
Oct 17, 2005
Beaverton, Oregon
Has anyone ever had a leak behind their TB? I did another boost leak and I can hear PSSSS behind the TB. I use soapy water but I can't see behind there. I want to know what it is before I take it apart.
Another question, my car was at a really high idle 24-7, so I turn down the BISS screw all the way until it stops and the idle went down to 900RPM. It was at 1700 RPM before that. I checked the throttle cable and tighten it a bit to 0 % when throttle is close but idle is still at 900RPM. What is going on?
Thanks
jerry
sounds like a nice sized boost leak.
you should have a brake booster line behind your intake manifold. those have caused some people some good boost leaks.
there should be some vacuum lines running behind/under your IM, check those out, make sure they are plugged in, as well as your egr valve's vacuum lines, they are nearby as well.
check all your vacuum lines and make sure they are on nice and snug, with no chance of coming off easily.
a boost leak test would be the first step you should take.
on a 2G you need a way to hold the ISC in the middle step (usually via a scantool) while adjusting the idle. if you just turn the BISS screw, the ISC will compensate for any changes you make.
Does anyone know where the FIAV is located on the TB, maybe a pic. I am thinking this may be the problem because at times I can smell the coolant when the motor is super hot.
Thanks
jerry
Yeah, it could be the FAIV, ISC, one many vacuum line connectors that hook to the manifold, throttle body shaft, even the intake manifold gasket could make it sound like its comming from the TB.
    • 4g63tv
    • 4g63tv
  • For sale 2g 99 2G parts
