Boost Gauge "T Fitting"
socal_eazye
May 19, 2007
San Diego, California
I recently bought a boost gauge off of ebay, from a company called Mookeeh Performance outta of Santa Maria CA. I bought it because the ebay ad said it had all the equipment needed for installation including gauge, "a pillar" pod, VAC. LINE/HOSE, FITTINGS, AND MOUNTING HARDWARE. They conveniently however left out the "t fitting" which I now know is fairly important. My question to you guys is were can I buy a "t fitting" does Home Depot or NAPA carry them or is there any method in which I can install with out the "t fitting."? Thanks!
All the places you mentioned should have it. Also check advance auto/kragens/autozone, etc. Fairly available anywhere that has to do with car/home/plumbing.
I believe you can run it without the t fitting. Connect it straight to a port on the IM? However the port you use for it is likely to be used by something that has to be connected anyways.
But don't settle for that, just buy yourself a T. I'm sure some guys in the SoCal regional forum here, will have extras that they can give you for free. Iknow I have a baggy full of them.
They keep them in the Help! section locally, and yeah, I have a baggie of the things too. It's like two bucks for a blisterpack of assorted sizes.
