Autometer boost gauge fitting
DSM4LIFE-AWD
322
10
Aug 6, 2009
Trois-Rivieres, QC, Canada
Hey guys, I received my used boost gauge and I want to install it. I don't have the stock nylon hose with the ferrule so I want to know what is the size of the adapter on the back. I tought it was 1/8 NPT but it only screw 1-1/2 turn so I think it could be BSPT ? I don't have any fitting 1/8 bspt at my shop to test it so can anyone confirm me this so I can order the right adaptor to hose barb ?
Thanks guys !
I bought it used on Talk to replace my glowshift. The seller didn't send the ferrule so I need to find a way to use it. ;)
Found my answer on Auto Meter and you where right on. Maybe my threads where dirty or maybe the 1/8 npt adaptor I tryed wasn't tap big enough and that why it was so tight ...
Thanks buddy ! :)
1/8" (10ft) with Ferrules
Product # 3223
For use with mechanical pressure gauges up to 200 PSI. Includes 10ft. of 1/8" Nylon Tubing, 1/8" NPT Male to 1/8" compression fitting, 1/8" NPT Female to 1/8" compression fitting, and 1/8" NPT to 1/4" NPT bushing.
DO NOT USE with Fuel Pressure, Brake Pressure, or Nitrous Pressure gauges.
Thanks but I wanted to know the adapter size so I can use a simple vaccum hose that is already use by my glowshift. :) Easier to connect on the throttle than the 1/8" hose ...
