Boost gauge reading
Should be closer to 12psi for boost and around 18 inHg for vacuum. Still on the stock 2g bov?
Like 2gGSXEclipse said do a boost leak test. You can find a write-up on it in the tech section.
I would suggest buying a 1g bov or a good aftermarket one. The plastic bov I took off mine was so weak I could even blow through it with my mouth OMG:toobad:
