Boost gauge leak
crazyquik22023
641
6
Sep 14, 2008
Akron, Ohio
So have been having a problem where my car would not boost past 15psi. I found out the line broke on the back of my autometer boost gauge. So I probably was boosting past 15psi but the gauge just wouldn't read past it. Although I don't think I am boosting to what I should be though. I have a 6262 turbo, 1.1 bar wastegate spring and my hallman MBC turned up all the way. The car does pull pretty hard but I am guessing with the 1.1 bar and the hallman all the way up I should be boosting close to 30 psi, correct? And it definitely isn't boosting 30psi. My question is do you think that a leak (line was ripped in half so pretty big leak) coming form the line of the gauge to where I have it teed (FPR) would cause a big enough boost leak to affect boosting? I am fairly sure this is my only boost leak.
I've done numerous BLT's. That is the only leak I can find. The test still will only hold pressure for a second like there was a massive boost leak. I'm just surprised a leak this small would cause symptoms like I am having but I'm sure it could.
Well thats good, just making sure. Keep checking for boost leaks. I find it's a lot easier with two people.
Ya I know me and my buddy were doing it the other night. Sprayed everything down with soapy water compressor was set as high as 60-70 psi and still wouldn't hold. No leaks could be heard except for the one from the gauge line. No bubbles anywhere either. I'm not a newb when it comes to engine work or dsm's in general. I just posted this in the newbie forum b/c it's kind of a dumb question. :sneaky:
I sure hope you are using a regulator and not running all 60-70 psi through your intake track. Fix the gauge line and then recheck.
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
