Boost leak? Boost gauge misreading?
gsexxx
166
May 4, 2012
Minneapolis, Minnesota
Just finshed putting the spyder back together. It is a 6 bolt 2.3 stroker with wiseco/crower pistons & rods, 2g head with stock valve train & springs w/ fp2 272 cams, new gaskets, with only 5,000 miles on the setup. When doing a boost leak test, the tank is set to 25 psi and seems to be holding boost. I have it at 30* past tdc and I still hear air exit exhaust. The boost gauge reads 2 psi when doing the blt. I fixed all the leaks I could find/hear (soapy water method). Just replaced injectors and seals/o rings. I don't hear any leaks and it holds pressure for 30 seconds+ when when I stop adding air. I am using a 29 gallon tank, and my tester doesn't leak.
I got the car last Friday and it had a bad boost leak that was not allowing it to go into boost when driving. He did a compression test and it all checked out. I just put in cams, 3g lifters, replaced timing belt, vc gasket, injectors, turbo, exhaust, pr mvs wastegate setup dumping to atmosphere, intake, valve cover, link v3 full, and afpr.
Boost gauge could be off? It's a practically new prosport boost gauge. I have an autometer I could throw in. Lines look fine. The boost gauge should read similar to the pressure the tank is showing, correct? Intercooler couplers are very tight, no leaks. Possibly bent valves since air is escaping through exhaust while at 30* tdc?
Any advice would be very helpful. Thanks in advance.
I am going to do compression & leak down test tonight after work. Hopefully I find something
Also, I have been doing some reading about the pcv valve. When I was doing the blt, I had the hose connected to the pcv valve. I am going to try plugging the hose and seeing if the head is still getting pressurized. If the pcv valve is letting air through, it would make sense why the air is escaping through the exhaust.
The egr was still on the car with the lines deleted, thus keeping the valve open. Problem solved.
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
