boost gauge jumps around
justinljs1
Dec 1, 2013
mt sterling, Ohio
I need some help with my boost gauge. Its a prosport performance gauge. Everything is hooked up right and ill the gauge does is randomly jump around. Could this be a sending unit or the gauge itself?
Possibly if your in doubt you can send it in, they have good customer service, bouncing around, be more specific. You could have some leaking lines.
Its probably the wiring not making a good connection on the back of the gauge. That was happening to my electronic prosport boost gauge when I would hit a pot hole or something it would jump around and reset it's self. I found out that the wires on the back of the gauge was not getting a solid connection when clicked in. So I just switched to a tried and true autometer mechanical boost gauge. But if I were you I would call or send in your gauge to prosport like iugrad92turbo said and explain to them your problem.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
