Boost Jumps At High Rpm??
1994talontsiawd
Jun 25, 2007
Topsham, Maine
I HAVE A DEJON TOOL MBC. AND WHEN I GET ABOUT 5000+ RPM, MY BOOST STARTS TO JUMP FROM 15 TO 10, AND BACK AGAIN NON-STOP. MY CAR HAD A CRACKED TUBE HEADER ON IT, SO I CHANGED IT TO A EVO III, IT HELPED SOME WITH BOOSTING FASTER, BUT NOT WITH THE SPIKING. I KNOW ITS NOT FUEL CUT, CAUSE IT DOES IT AT HALF THROTTLE, AND IT JUST JUMPS AROUND. ANY IDEAS???:talon:
have you disconnected the MBC to see if it will hold steady boost with just wastegate pressure? what kind of turbo are you running?
I'm running a 16g turbo. And yes I hooked the factory one back up, and it goes to 10, then up to around 11, then back and holds at 10. I figure thats just boost spike. Think the dejon mbc is bad?
