boost drops off after 5500rpm's
WesD
Jul 24, 2002
my boost is dropping off after 5500 rpm's. i can't figure it out, any ideas from you guys would be great....here's the story
i have a 16g turbo, fmic, 550's ,fuel pump, some engine work done..anywho when doing second or third gear pulls i hit about 17-18psi till i get to 5500 then it drops to 15 by 7000...it's starting to get on my nerves... :mad:
I agree that it seems to be a leak on the intake or exhaust. Check all the nuts/bolts on the exhaust to make sure it is tight, leak check the intake at 20 psi.
You should find your problem once you do this.
