Boost controller problem(can't get to work corectly)
Dsmer_95tsi
Mar 4, 2004
Potosi, Wisconsin
ok... so i used to have this crappy home made boost i made at the hardware store, which i could get to set at about 10psi consistantly, but no higher(it did the job) but i recently got the dejon tool boost controler and have it hooked up exactly the way i had the other one, and it is as if its not even hooked up. the boost just spikes straight to 25psi plus if i give it ne thing more than half throttle :mad:
You need to give more info, what type of mbc (ball and spring.....) and give detail description of where all the hoses are coming and going, pics would be great.
10 psi is the stock setting for the actuator so it's possible you never hooked up the home made one correctly tp begin with.
ya, i figured the problem out. the ball bearing in the boost controller for what ever reason was stuck and wasnt moving around, so no matter how i ajusted the boost controller it never made ne difernce.......it works fine and runn 18 psi consistantly now :thumb:
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
