boost controller / gauge install
Id be glad to help you out, but a little more info is needed.
Manual Boost controller/electronic?
Type of Boost gauge?
You typically run the boost gauge from the vacuum line that goes to the fpr. As to the the boost controller, I always set the mbc, on line to the wastegate, and the other line to a source that sees boost such as the compressor housing or J-pipe.
boost controller:
vacum source > boost controller > wastegate
Boost gauge:
any good vacum source
simple as that
