Boost and water temp Gauge Help
talon55
119
Jun 13, 2006
somewhere, New York
I want to install my boost guage were do you tape the hose at? If you can show a pic.
93 Eagle talon TSI AWD TURBO STOCK SETUP
Thanx:dsm:
ya thats the boost controller you sent me im looking for the boost guage were you tap that to?:dsm:
Tap into FPS vacuum line (see image)
You have three taps on the intake plenum (excluding the TB) used for the: PCV, brake booster and fuel pressure solenoid. The FPS is located on the front side of the plenum closest to the drivers side and terminates to a solenoid located on the firewall. Simply "T" into this line and connect your boost gauge.
For more info, try searching the site or check out these helpful links:
http://www.dsm.org/how-tos/gauges.htm
http://www.vfaq.com/FAQlocator-index.html
I have a autometer mechanical water temp quage does anyone know how to install one? on a 1g 93 eagle talon tsi awd:dsm:
The gauge should have come with instructions that are pretty good. As for a place to take the source from.....you will have to use one of the holes in the thermostat housing. There are a couple that usually aren't used. Figure out which one you aren't using and use the adapters with the kit to make it work. If the kit doesn't have the right adapter you need you could always drill and tap the housing. However be aware that the metal is thin and sealing it is tricky. Good Luck
cooling problem solved... Thanx guys
put a koyo racing aluminum radiator, new radiator cap, and new 160 thermastate...
:dsm: :thumb:
