boost and fuel problem
carmaevo8
Apr 18, 2011
o, California
i have been trying to get my car running correctly since i have bought it in febuary, but this is baffling me,
to start my mods are listed in my profile(except my turbo back exhaust all 3 inch and i have a cat for now. the issue is my car is over boosting bad, i cant go WOT without it sputtering a bucking, ok thats the symptom.
as far as i know the turbo is stock, i have tried to put a MBC on it and turn the boost all the way down, for some reason it didn't work, so a friend thought we should put it on static waste-gate pressure.(the hose now goes from the turbo to the waste gate) and it still over boosts.
i think i have solved the fuel problem, but i am not sure, the book i have on my car says the fuel pressure regulator should be around 26-28 PSI, when i put my vacuum tester on it was reading 9.3 PSI, so i did more checking and i think either my fuel pump is bad or i have clogged lines, not sure how to check for a clog without talking the lines off the car.
so my question is does anyone have any idea about these issues, thanks in advance
no really guys, i need help,
Have you tried another waste gate actuator?
Do a vaccume test on the actuator and verify that it's opening.
The free flowing 3 inch turbo back exhaust will cause creep on a not modded turbo..
The 1g manual fuel pressure should be 26-28psi..Have you replaced the fuel filter since you have bought the car..A little maintenence goes a long way..
  • For sale 2g 2G AWD Rear Knuckle Set
    2G AWD Rear Knuckle Set $230 + shipping and paypal fees* these are out of 2GB so you get a...
  • For sale 2g 2G GSX/GST Front Knuckle Set
    2G GSX/GST Front Knuckle Set $150 + shipping and paypal fees* on the L side Knuckle the little...
  • Wanted Looking for an Evo 3 16g
    Anybody selling one let me know. Tried ebay and its all knock offs
    • heresjimmy42
  • For sale 1g 1990 STM shifter base bushings
    1G 1990 STM shifter base bushings.
    • drich970
  • For sale 1g 1G Radium fuel rail
    1G Radium fuel rail with built in FPR -8an feed and return
    • drich970
