Bolts?
Uber10
Mar 23, 2012
Montgomery, Alabama
i have a 2g eclipse and most of my bolts are either missing or stripped
i need the size of the bolts for the following :
1. all the engine mount bolt from the front
2. starter bolts
3.axle bracket bolts
Thank you very much.:)
Just grab the Mitsu ASA and have at it. If you are using 64 bit windows get ASA if you are using XP 32 bit then wincaps seems fine. Scroll down about 1/2 way or so and see mmc-asa_usa.exe.
http://www.mitsubishilinks.com/
Or just call mits and the can give you the dimensions. My car has been apart some many times, I lost all tranny bolts and Flywheel bolts. Mits was able to tell me what thread pitch how long and the grade it was.
