Body repair?
craracer05
Supporting Member
357
90
Sep 29, 2005
Warren, Ohio
So i'm getting ready to start some rust repair (major rust repair i should say), I'm just wondering what gauge steel should i use to patch the body. I have a lot rocker rot right in front of the back tires under the plastic molding. I'm going to start there since the work will be covered under the plastic and will leave me some room for error.
You could also glass it. I like fiberglass because you can make it do whatever you want pretty easily. It just depends on what you're comfortable with. If you're welding just remember to use a lot of tack welds and only do a few at a time so the panel doesn't get to hot and warp otherwise you'll have a lot more straightening and filling than you started with. Laying a bead will warp the crap out of a body panel. I learned from experience. You may have already known that but it's something to remember.
Laying a beed will warp the crap out of a body panel. I learned from experience. You may have allready known that but it's something to remember.
Funny, I was just talking to a co-worker 30 minutes ago on this very subject. He is also doing some metal replacment body work to a Toyota pickup and was stressing the importance of not running a full bead. Spot welds are your friend...
