blue smoke under hard rev or boost
thereef
100
Oct 5, 2010
Wichita, Kansas
Leads me to believe it's a bad seal in my 14b, but is there any way to confirm this? I'm pretty worried it's blow-by for some reason.. I guess just me preparing for the worst.
I can hold idle at ~2500rpm all day long and not get any smoke, but if I do hard revs (wot) I get a very small puff in the lower rpm range, but once I hit boost I get a nice large cloud of thick blue smoke that hangs for a long time down the road.
I'm going to try to get my hands on a leak down test, already tried a compression test but the compression tester had a crappy flexible tubing and I couldn't get it screwed down into the spark plug threads adequately.
Car feels like it has plenty of power. Idles like a champion..
I would check for shaft play in the turbo, for starters, worse case pull the turbo apart and check it out there is a video on youtube for turbo repair.
Sounds like you know what to do... Get a better tester and go from there. You won't know until which way to go until you do that first.;)
iugrad92 -- is shaft play a definitive sign of leaking seals?
GRAVEDIGGER -- you mean I actually have to do WORK? *sigh*
I'll see what I can find out tonight and report back. If anyone else has anything they want me to do/try let me know and I'll get you results come sundown tonight.
I quick way to see is to just do a wet compression test. Its easy and fast.
A leak down test would be better, but takes a little longer.
Just do a regular compression test, write down each number. Then do a wet compression test and compare the numbers.
Then check for shaft play.
Yes this ^^^.... It's quick and easy to do.:) If you've got considerable up and down movement, or ANY in and out movement in the shaft you probably are leaking oil past the seals in the center section.:|
This ^
I have the same.problem. No shaft play n 150 across the board. Could be blow by. Im installing a catch can n seeing where else it would take me
