blown turbo, new install help!
gstmammo
43
Apr 11, 2012
Evansville, Indiana
alright guys, first off im sorry this is my first boosted car so forgive my noobness. heres my situation, I have a 98 gst and the previous owner thought it would be okay to try 18 psi on the stock turbo, and well blew it, and instead of fixing it or getting a new turbo the dumba** just converted it to N/A which i still do not understand. I went out and got a turbo off cl for $40, its the 14b turbo and I understand that I need to get a j bend and oil lines and stuff, but my question is how do i go about installing the turbo? I have no idea even where to begin...if yall can help that would be sweet
You will need a jack, jack stands, metric tools (8-17mm), an 8mm Allen wrench, new oil, oil filter, coolant, copper washers, feed and return lines, exhaust, manifold, j pipe, and all the nuts and bolts needed to settle the turbo in place. Since you got a 14b, you will need the oil feed line from the cylinder head, an oil drain tube, coolant lines, and all the necessary copper crush washers that go along with all the banjo bolts.
