Blown turbo for your viewing pleasure
Towlieee
May 7, 2004
St. joseph, Missouri
This is a stock 14b outa my friends 91 laser..
He ran 18-21psi for about 2-3 months on this turbo.. The last day in the morning it would only spool 10psi so we shut it off, later we went to drive it and flooring it, it barley moved.. Ended up catching a pretty big fire under the engine bay that we put out.. Here is the turbo after that
http://www.sounddomain.com/memberpage/454627/7
OMG Wow. Now there's some shaft play.
Is your friend going to upgrade to another turbo? If so, which?
Umm, how did the turbine wheel get destroyed? I was thinking it was from the bits and peices of the comp wheel, but that means they went through the engine. Not cool. :(
Well, in order for the comp wheel parts to hit the turbine blades it would have to be in the exhast system, hence gone through the motor. Unless it blew out the whole center section. But I see your point, i would guess if the comp wheel parts made it through the turbo they would probably get caught in the intercooler. Maybe when the comp wheel hit the turbine wheel did as well, and destroyed itself.
Just the exaust blades where hurt..
The intake side blades where just mangled a lil bit, but they were still intact..
The exaust blades were in the o2 housing and some were missing in the exaust system LOL
