Blown head gasket but no smoke
guamboyeli
125
May 24, 2012
North las vegas, Nevada
Ok so every now and then I have to refill my radiator with coolant... It doesn't make any bubbles in the radiator, and the oil is the same hasn't mixed... No leaks and no smoke... Where/ what should I look at???
You need to get a coolant pressure tester and pump the system up. This should show your leak or Atleast give you a better idea. Have you done a compression test yet to see which cylinder the HG could have blown at?
thanks guys Ive totally forgot about the pressure tester... but yea... i ran the car in my garage for around 30 mins, drove it 10 miles, brought it back and nothing... no leak whats so ever.... unless someone is secretly stealing my coolant when im not around
heater core would be my first guess.
If you have antifreeze in the system, drive the car and click the defrost on and fan on high.
If it is super minor, you will just have a sweet smell, if it is a bit more of a leak, the windshield will mist up on the inside.
  • Wanted 6 bolt NT water pipe
    • chrisman287
