Blown Engine?
TeeWX98GST
111
Jan 13, 2008
Cresco, Iowa
Well I was on my way out of town today and ended up following a semi for about 20 miles. About 15 minutes into the trip I was giong about 60 and all of a sudden my car felt like I hit the brakes or something because it dropped down to about 50. I didn't know what to think of it at first but when I let off the gas my car shut off. I got it on a flatbed and got it home. When I went to try and fire it to see whats up it started and ran at probably 2-300rpm really low idle and it was struggling to run almost. I also hear a knocking sound coming from the engine bay. Like possibly something is blown. Anyone got any idea what it could be that would suddenly just go like that? I'm going to go drain the oil and check :(
does this "knocking" noise from the engine get louder when you rev it?
where under the hood is the noise coming from?
worst case scenario would be spun bearings:barf:
I dropped the oil which was fairly new and I noticed it is green. Like dark green/brown in color and has lines that seperate it into clumps on the surface. So basically I have coolant in my oil I'm geussing.
Knocking in engine =/= headgasket?!
I don't get any noises when the head gasket goes on my car, maybe there's more then just a bad head gasket there.
He is right i blew the engine on my 99gsx if the knocking is getting louder/faster as you rev it more then likely its time to rebuild or replace.
Here we go...
<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://i260.photobucket.com/player.swf?file=http://vid260.photobucket.com/albums/ii1/TeeWX/1998%20GST/033009_150200.flv">
Things I plan to do about this so far.
1: :cry:
2: Inspect the crank OD and rod ID
3: Clevite Bearings
I will post pics of my crankshaft, rod, and the bearing I spun as well as measurements when I get to it.
  • Wanted 6 bolt NT water pipe
    • chrisman287
