2G blowing white smoke help! 95 gst
eclipsegst0
May 6, 2010
Massapequa, New York
Hey guys I'm blowing white smoke out of my exhaust. Not all the time but sometimes. And sometimes there is A LOT of smoke and some times there's only a little. I changed my head gasket, changed my valve sleals, got my head milled, and literallyy changed every every gasket on my car. And its still blows the smoke. Btw I have 2 boost leaks...... Could that be the problem? Like idk if a boost leak wld lead to white smoke. I'm going to fix the leak tomorrow. Also sometimes my car won't past like 4 grand and I also believe that leads to the boost leak. Thanks for ther help!
Either A: Burning coolant, Where is it smoking from? Check for crappy heater lines since you did replace all gaskets. B: To me it sounds like the turbo because of the boost leak and smoke. Get the turbo checked.
