Blower Motor Switch?
Razor
51
Aug 7, 2002
San Francisco, California
Hi,
My blower motor stopped working about a week ago. In every setting it doesn't work, except if I turn it to high and push in the A/C button, I can hear the front engine fan working, but NOT the blower motor itself. Other than that no other settings work.
I already changed the fuses, blower motor resistor, relay and checked the blower motor itself by hooking it up to a 12V battery.
The only thing I suspect the problem to be is the blower motor switch; however, again it works only for the fan in the front engine and NOT the blower motor itself when the A/C button is depressed.
So should I change the blower motor switch (is it hard to do so) or does it mean it is something else?
Please help it is about to reach triple digits here...
I managed to take apart the dash, but have yet the pull the whole HVAC assembly, because the lever cable are still giving me a hard time. But I had enough room to detach the harness from the switch.
Does anyone know how to change the switch from the HVAC assembly? I assuming one can because the dealer does sell just the switch.
I plan to go and get a blower switch at the junkyard. I really hope it works, because I just about run out of ideas.
Thanks for the response.
