Blower Motor Problem
luisgil
156
Jan 10, 2013
Paterson, New Jersey
So I fixed most of my problems with my car and there is one big problem left. I can turn the blower motor on without having the key in the ignition. I just cant think of what may be causing this. Everything else is okay. The blower motor is the only thing that can turn on without the key in the ignition. Please help.
Either that or there is some disconnection with your wiring that is hooked up to your blower motor, It happened on mine once, and there was a slight disconnection, with yours it could be different.
Were you doing something with the wiring in your car that could have caused this or has it always been this way? I can tell you tracking down wiring problems can either be obvious or the biggest pain in the a** you could ever imagine. Easiest thing to do is to check a wiring diagram to find out where the wire is supposed to be going then just run a new wire. Tearing into the wiring harness is usually more trouble than it's worth.
Were you able to find a wiring diagram on Alldata? That would help out to know where the wiring issue would come from.
