block rebuild, clear the fog...
Eclipsethis90
126
Jul 16, 2003
Pleasant Garden, North Carolina
OK so I've spent the last 3 hours or so reading and gathering information on rebuilding my bottom end. I am wanting .020 over Wiseco's with the 8.3cr. I keep reading the wisemen and mods and others talk about how important it is to "find a good machinist". I just moved to Beaufort, SC and I finally have saved enough to rebuild my whole engine. I know to ask if they are going to use a tourqe plate while boring and honing, and i know that .003 to .0035 is the recommended piston clearance to the cylinder wall, but I still have no idea how to gauge this shop's reputation. What kinds of questions should I ask my local machine shop to see if can utilize thier services and trust them? :confused: Also, would it be wise to assemble the engine myself and inspect thier work afterwards or let them assemble it after the machining? Note: I am a machinist so measuring the bore diameters and assembling the engine doesn't bother me one bit.
i would reccomend going to several automotive shops and asking them who they prefer for machine work. most shops will know the best machine shop in town. hope that helps
not a bad idea, the only issue i have is the shop down here specializes in honda. I don't know how much rebuilding a honda bottom end has to do with a mitsu, but I'll give them a call tomorrow. Thanks for the tip, I never thought of that.:D :talon:
Asking other automotive shops wouldn't be a bad idea. I prefer to stroll in and just talk to the machinist and try to get a feel for how they are and how they do their work. I went through many local shops and found most of them to be against imports and 4-cylinders, and that scared me. I gave up and brought it to Dave Buschur's to get bored, honed, tanked, etc. The next day I found an excellent local machinist, but it was too late.
As far as assembly, I would do it yourself. That way you know that everything was done to your specs. You say you are a machinist, you'd have no problem at all assembling it.
Good luck!
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
