Block Guard's
Leonthefaded
Supporting VIP
1,622
5
Aug 3, 2011
Ewa Beach, Hawaii
How many of you 420a NT with turbo guys are using block guards with your engine builds or turbo setups?
The 420a is a semi closed deck. It has plenty of support for the cylinders. If you look at the deck surface than look at a honda deck surface you will see why it is not needed, and how it wouldn't even fit because the cylinders are tied to the outer block.
+1 and ours is iron and hondas are aluminum. These blocks have been taken over 700whp.
Thank you for the fast response! I was purchasing a block guard for a honda motor and thought about buying one for my 420a, but as you said it is not needed.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
