2G Black top CAS wiring to replace 90 style CAS
Yamahaulin
695
12
Jan 30, 2010
Bowling Green, Kentucky
I have a 2g with a 6bolt. Currently i have the green top that has no plug on it. I have a black top i want to swap in. Does anyone have a wiring diagram so i can switch these as the wires are different colors.
no on the green top there are 4 wires white, yellow, red and black. On the black top there are 2 black wires and a red and a black. I need to know how to hook the black top up in place of the green top.
They go in the same order , so if you line them up next to each other with the thicker black wire at the end just connect the wires in the same order. white to white , yellow to the thinner black wire , red to red and black to black. The thicker wires are the power & ground.
