biss screw size???
You can find the part number on www.VFAQ.com and its less than 5 $. i actuallly ordered one in blacksburg then moved so i need to order another one up here and get one myself. right now i have a small screw wrapped in duct tape to fill the hole : (
(Mitsu part # is MD614948 and it's called, "Adjusting Screw, Throttle Body". You need a #5 O-ring (3/8x1/4x1/16, available at most hardware stores), now available as Mitsu part # MD608806. This goes right under the head of the screw in that valley that looks as if an O-ring should go there.). --------from vfaq.com
The o-ring for the biss screw is MD608806. The biss screw is MD614948. The cap that goes on top of the biss screw is MD614532. :thumb:
