Biggest injectors without tuning
flosho
42
Sep 17, 2004
Medford, Wisconsin
I have a 98 GSX and just wondering what are the biggest injectors and fuel pump i can go with without fuel management?
What PSI will the stock injectors max out with then? Can I bump up to 18 psi or so? I'm also running a evo3 b16g, stock exhaust, etc...
I would recommend running on stock boost until you get some sort of logger, fuel controller, some 660's, 190 fuel pump, and a turboback exhaust.
18 psi would be way too much for stock injectors. 15psi Max I would say, but like mentioned you can't tell un less you have some form of logging device. It probably wasn't the best move to just throw on a bigger turbo like you did, but that is not my decision to make. I recommend for you to read the upgrade paths in the tech/diy at the top left corner. Also your not gonna get hardly anything from that turbo with a stock exhaust, not to mention no fuel upgrades/tuning devices. You could end up seriously hurting something.
Most you can run without fuel management:
190 LPH Fuel Pump
Stock 450 cc Injectors
Most boost you can run with stock injectors:
14-15 PSI
If you wanna go to anything more than that, you'll need to be tuning. And going with a larger fuel pump than the 190 will require a fuel pressure regulator.
Ok thanks. I don't know if I want to spend all that money on upgrades yet, I was hoping to maybe just bump up the injectors and fuel pump and run a few more PSI.
Very true, however the stock turbo took a shit shortly after buying the car and I bought this as a future purchase, rather than buying a stock turbo and later upgrading the turbo, spending yet more money.
Whats the best tuning device for the money? The cheapest? I realize that the turbo needs to breathe, and that larger exhaust would give it some breathing room, just haven't had it top priority as of late.
Get yourself a S-AFC if you're wanting to tweak the fuel. It'll run you about $300-350. And you're gonna want to put a decent exhaust on your priority list, especially with that turbo of yours.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
